Trouble using Real Time "Wait" and "Wait until"
My problem is:
When I use Labview Realtime with a while loop in CompactRIO, if I use a "Wait" or "Wait Until" function with unit "us" ot "ns" the loop will stop there forever. However, if I set the unit to ms, the loop can normally run.
Besides, if I run the same vi under the host computer (not under CompactRIO), the loop can run correctly with whatever units "ms", "us", or "ns".
Can anyone help me to solve this problem or tell me why?
Thanks!
(2,738 Views)
Hi RT,
I noticed you've got this question posted on another forum (http://forums.ni.com/ni/board/message?board.id=270&message.id=3369). I'm going to close this post and continue the other post. If you're confused about this forum a question should be posted to, just choose the one you feel is most appropriate.
Michael K. | Applications Engineering | National Instruments.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(2,713 Views)
