Trouble with Matrix Mathematics
Alrighty, the sensor comes with a calibration sheet that gives the specifications for the loadcell and the max reading for each channel.  It also has the pin layout which I used to hookup to the NI 9205.  Along with this information a calibration matrix is provided to convert the output voltage off of the sensor into the loads with engineering units.  It is provided in the form of Calibration Matrix X Output vector to get Engineering Units.  With my zero experience in labview, I created and intialized an 11x11 matrix.
Message 11 of 14
(325 Views)
Thanks. Do you have a link to that manual?
Message 12 of 14
(318 Views)
Cal + spec
Message 13 of 14
(309 Views)
Thanks! (I wasn't obvious that the values are related in 3D)
Message 14 of 14
(301 Views)
