Trouble with SCC configuration
Hallo,
I have two computers. Computer A contains a master directory for a project.
This master directorie is in a folder which I declared accessible for
network use.
On Computer B I mounted a network drive to this folder (net
use..../persistent:yes).
When I try to select my Master directory on B via this network drive
SouceCodeControl returns an error
"Error 8 occurred at OpenFile in Write SCC Pref.vi->Administer Builtin
System.vi->Source Code Control Options.vi"
Possible reasons: File permission error
Both machines run XP.
Can anybody help me to solve or approach the problem?
Thank you
Oliver Friedrich
(2,386 Views)
Did you set the correct access rights for the directory on A? Is the user logged in on B allowed to read/write files? Is it possible for you to access (read/write) the files on the shared directory on A using the Windows explorer on B?
Jochen Klier
NI-Germany
(2,386 Views)
