11-28-2005 02:19 AM
11-28-2005 02:47 AM
Check your flow control, since you (ab)use your hardware flow control lines. Shouldn't be set to hardware ![]()
Next: Set the state of DTE and RTS 'by wire' : drop the visa properties node on your diagram and choose :modem line settings to set the DTE and RTS line levels.
If you use a notebook you might get into trouble, sometimes the voltage level is to low to power circuits. Use a USB2RS232 cable in that case.
