Troubleshoot with Lecroy 9404M oscilloscope
Good Morning
Currently designing an Oscilloscope VI using LABVIEW FOR Lecroy waverunner 9404M. I have used waveseries as the instrument driver for labview.
Using Ethernet to communicate with the lecroy . Having an error with code 1073807257
 Please suggest any solution.
Thank you.
Regards
Ayesha Zaman
(488 Views)
Is this instrument recognized by NI-MAX?  Seeing as it is using a TCP connection, I did not see any declarations for connections to the device at the start of your code.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(455 Views)
