TrueTime Card and how to interface with dll file!?
I am trying to interface with a PCI-SG 2U (IRIG) timing card (Used to made by TrueTime, now Symmetricom).  Does anyone have a solution for this card in LV 2009?
If not, can anyone give advice on writing code to interface with .dll file?  I am not sure how to pass through the "GENERIC_READ | GENERIC_WRITE" into the function to open the device. The function says to open it is:
TT_OpenDevice(boardID, GENERIC_READ | GENERIC_WRITE, &hDevice)
No clue on how to pass this in.  Can anyone help?
Thanks -
Tom
(3,112 Views)
Hi Tom,
do you have a header file for you dll? If yes, then the values for Generic_Read and Generic_Write should be defined there.
Edit: as you can see here, you should have also the source code if you have the SDK. From there you can read the defined values for what you need.
Mike
(3,107 Views)
Thanks Mike.  I do have the .h file and the sdk information.  I went through and used the Import>Shared Library Tool and was able to find all the header information that way.  I guess that my problem/question is, the documentation says that it is a DWORD to pass as an input, but LabVIEW says it is a uint32.  I guess the real question is, what the heck do I pass in to the dll function?  Should it be the string "GENERIC_READ | GENERIC_WRITE" or something else?
Thanks -
Tom
(3,095 Views)
Hi Tom,
it is a number. Connect it as a UINT32. The needed value should be part of the header file.
Mike
(3,069 Views)
