Trying and failing at performing velocity measurements
Not sure which of those counter types I have.
I'm using an NI-9178 chassis and NI 9411 digital input card, both of which are less than a year old.
Message 11 of 12
(1,025 Views)
The manual for the 9178 refers to an STC3 chip.  I suspect it's got essentially the same behavior I described for the DAQ-STC3 chip in desktop plugin boards.  Unfortunately, that's bad news for your particular data sync needs.
A possible workaround is to configure an additional counter to do 2-edge separation measurement from the Arm Start trigger edge until the active frequency-measurement edge.
-Kevin P
Message 12 of 12
(1,014 Views)
