Trying ot connect a RWD 462 SYRINGE PUMP TO A PC
Hello all,
I'm currently new using LabVIEW a RWD462 syringe pump that I'm trying to connect to my pc in order to connect it to LabVIEW. how can i connect it to my pc? which ports can i use? what cables do I need? the syringe pump has no driver available from the manufacturer. does anyone have a code or a driver that would work with this syringe pump? attached to this forum is the user manual.
RWD Syringe Pump R462 User Manual (rwdstco.com)
(705 Views)
THe manual does not have any information about the communication protocol. There is a usb/RS-485 and Digital IO ports, but the manual has no information about how to use the Signals. You may get more information from their tech support.
(696 Views)
