Trying to Integrate Remote Desktop Connection Application to my LabVIEW Code
Hi all,
 I want to integrate Windows Remote Desktop Connection application with our LabVIEW code. as I understand we can do that through AciveX Control, but i could not understand how to select the methods or properties of that Active X control.
Please help me.
Thanks in advance.
(2,253 Views)
That might not be possible in pure LabVIEW.
Here Remote Desktop using C#.NET - CodeProject it mentions:
Due to security reasons, you have to implement an interface (IMsTscNonScriptable) to cast it separately.
Other then that showstopper it's pretty straightforward, but you have to start with a front panel ActiveX object.
(2,231 Views)
Hi
as you suggested I tried  but, I am getting the screen as below and after 2 or 3 seconds it's disappearing. I am not getting where should I write
"Due to security reasons, you have to implement an interface (IMsTscNonScriptable) to cast it separately." part. and not how to append the scree into activex container.
(2,201 Views)
@KiranTeja wrote:
Hi
Do you mean you get a remote desktop connection?
If so, you can skip all the comments about IMsTscNonScriptable...
You didn't post all your code (only a partial image). If the screen disappears it's probably something you do or need to do on the left of the VI, the part we cant see.
(2,181 Views)
Actually I am not getting the connection. please go through the VI which I am sharing. you can understand it clearly
(2,177 Views)
If you're not getting a connection, we're back to the part where " you have to implement an interface (IMsTscNonScriptable) to cast it separately." is a showstopper.
Showstopper as in stopping the show... As in not possible.
At least, I see no easy way out.
Best bet is to use C\C++ to "implement an interface (IMsTscNonScriptable) to cast it separately.".
Or maybe to look for a .NET wrapper or other replacement.
(2,169 Views)
Do note that there's no forced sequence between setting the bottom properties and the connect
The connect might happen before the password is set. Use 1 error wire to synchronize everything in time...
Small change, but who knows.
I don't see why you use Settings5 (resulting in Settings4) to set the AuthentificationLevel, and Settings9 (resulting in a Settings8) to set EnableCredSspSupport and ClearTextPassword. Is there any logic behind it?
(2,167 Views)
