Trying to configure NI 9147 cRIO chassis
I have a 9147 cRIO expansion chassis that I wish to use in Scan Mode. I can see it in MAX, but not the 9070 RS-232, or 9375 DIO modules installed. I can access the chassis with the USB or Internet Explorer so I think I'm close (I hope).
Anyone have an idea? Attached is a shot of MAX
(1,567 Views)
Hi Andy,
In MAX you usually only see the chassis, but not the installed modules. (Atleast this is true for all cRIO90** devices I have worked with.)
When you setup a LabVIEW project with your cRIO you can detect the installed module in the chassis. The project is the place where you manage the modules!
(1,519 Views)
Thanks for your reply Gerd. I had everything setup right then I read a statement somewhere that said it only works with LabVIEW 32 bit, not 64 bit. I tried 32 bit and everything showed up in the project tree.
(1,491 Views)
