07-20-2021 09:26 AM
I have a 9147 cRIO expansion chassis that I wish to use in Scan Mode. I can see it in MAX, but not the 9070 RS-232, or 9375 DIO modules installed. I can access the chassis with the USB or Internet Explorer so I think I'm close (I hope).
Anyone have an idea? Attached is a shot of MAX
07-22-2021 06:25 AM
Hi Andy,
In MAX you usually only see the chassis, but not the installed modules. (Atleast this is true for all cRIO90** devices I have worked with.)
When you setup a LabVIEW project with your cRIO you can detect the installed module in the chassis. The project is the place where you manage the modules!
07-26-2021 07:14 AM
Thanks for your reply Gerd. I had everything setup right then I read a statement somewhere that said it only works with LabVIEW 32 bit, not 64 bit. I tried 32 bit and everything showed up in the project tree.
