Hello Thomas,
Perhaps I don’t understand your question. I don’t appear to have any trouble running this VI. For example, if I want to reduce 100 points to 4 points I select a reduction factor of 25. The VI then takes the first 25 points and finds the min, max, last, mean, or median and stores 1 number to represent those points. It then does the same with the next 25 points and so on until it has an array of 4 points to output. Is this not the behavior you are seeing?
Best Regards,
Chris J
