Hello
Thanks a lot for the help. Yes, as you have interpreted my data is in a 2D format with its first column linear. My original waveform is an optical signal that is plotted as intensity v/s wavelength. I want to use this as the input to LabVIEW and plot the histogram of this signal. I don�t want a complex histogram just a simple histogram is enough.
This example has an input signal, whose histogram needs to be computed. Maybe it can look something like the noise whose histogram has been plotted in Running Histogram.vi example provided in Search Examples. For the parameters of the histogram it would be intensity v/s bin_width and since the wavelength (x-axis) ranges from 490 to 890 nm which is 400 nm dif
ference it would be suitable to have 32 bins i.e. a bin every 12.5 nm.
You are free to make any changes to the above. Please help me,
Regards
