Trying to download files from an URL in a proxy server environment
I am trying to download a file using LabVIEW with a simple DataSocket Read function but I am getting this error message: "LabVIEW:  Path not found, FTP login incorrect, or no FTP write permission." I am trying to do this at work and I know we have a proxy server. Even If I use this simple code, it does not work:
How can I tell LabVIEW to use the proxy server?
José Rodrigo TÁGER
(6,905 Views)
Hello JR_Tager.
Thanks for using the NI Forums. From what I see in your code you haven’t initialized any session to a server. Please take a look at the Simple DataSocket.lvproj within the LabVIEW Find Examples section.
Please check also this Datasocket tutorial that will explain the main functions and help you with your application.
http://www.ni.com/white-paper/3224/en/
Hope you find this information useful!
Luis C
Luis CT
(6,843 Views)
Hi LuiE_C
Thanks for your reply. About that, I thought there was no need to initialize a session. For example, checking at the paper you are pointing below, we have this:
This is what I actually try to use and it is not working. I am 100% sure it must be because of the proxy settings. That is the reason why I am asking how to tell LabVIEW the proxy settings.
JR TÁGER
(6,832 Views)
