Trying to fınd drivers for Keithley 2182 that work for Labview 7.1
I am tryıng to find drivers for a Keithley Instruments 2182 nano-voltmeter that work on Labvıew 7.1.
Thank you for your time
(2,612 Views)
Your version of LabVIEW is way too old.
I even have some doubt that saving for previous version will work.
7.1 used a complete different visa driver.
the closest version available is 8.2
Benoit
(2,581 Views)
Hi Ahmet,
even LV7.1 has VISARead/Write functions available.
So in worst case you read the programming manual of your Keithley2182 device to learn about the commands needed to control your device. Then send those commands using VISAWrite and read the device answer with VISARead!
(2,578 Views)
His question is about to find driver already written. I think That he know he can write it by himself. Writing driver is time consuming. Unless someone has driver already written for that version... He will indeed has to write it by himself.
Benoit
(2,575 Views)
Hello Ahmet,
From what I can see, the earliest available version is for LabVIEW 8.2.1 .
Have you tried requesting that driver? I have provided a link to the form.
http://sine.ni.com/apps/utf8/niid_web_display.request_driver
Malkolm A.
(2,564 Views)
