Trying to fit a curve with restrictions
I am trying to fit my experimental data with my own function y=a*exp(-x/b)+(1-a)*exp(-x/c) and I want the "a" paremeter to be >0 when doing the fitting.
Is there anyway to do so?
Thanks!
(2,751 Views)
Assuming you have a recent LabVIEW version, try the Constrained Nonlinear Curve Fit VI. Good luck!
Message Edited by altenbach on 04-03-2009 05:43 PM
(2,743 Views)
what if I use 7.0 vision? Is there any way to realize Constrained Nonlinear Curve Fit use Labview 7.0?
(2,709 Views)
 Yes, but you have to do it all yourself from scratch. 😞
(2,698 Views)
Try fitting to (a^2)*exp(...) + (1-a^2)*exp(...)
a^2 is always positive, so the constraint is now implicit in the model.
-Jim
(2,683 Views)
