Trying to get an example working, using User32:SendMessage
Hi, My ultimate goal is to get a (non-IMAQ) video-overlay working with avicap32.  I found a VB example that does it but that example is making calls to User32:SendMessage.  So I'm trying to get a simple example of calling SendMessage to work.
I've attached an example VI which tries to use SendMessage to retrieve the window bounds of the example VI. The example allocates a pointer to 16 bytes (four "longs") needed for window "RECT" values.  By default, the diagram calls SendMessage which does appear to populate the destination array - but the values are not right.  I say they are not right because:
- they are typically way too big
- they don't change when the window bounds change
- they do change, occasionally, even though the window bounds haven't changed
To me they the values look like pointers, though that's just a guess.
Any help is appreciated!
(P.S. The prototypes for LabVIEW.dll function are found in extcode.h)
(5,321 Views)
I see the same behavior running your VI no matter where the window actually is. I can't say for sure that EM_GETRECT message isn't working correctly, but according to this:
https://msdn.microsoft.com/en-us/library/windows/desktop/bb761596(v=vs.85).aspx
EM_GETRECT seems to return the bounding rectangle of an edit control rather than the bounds of the window. Are you sure it should be returning the bounds of the entire window?
Can you post the VB example that you're working off of?
(5,259 Views)
Try GetWindowRect
George Zou
(5,256 Views)
Thanks elcaverado,
You may be right about EM_GETRECT applying to "edit-controls" and not a Window.
If that's the case, I need to find another simple message. At this point, I only want to verify my ability to call SendMessage and get some expected results.  Eventually I'll use the message WM_CAP_DRIVER_GET_CAPS  to retrieve "CAPDRIVERCAPS" structure in order to check its "fHasOverlay" property.  The VB links are on my home-PC - will send them later.
https://msdn.microsoft.com/en-us/library/windows/desktop/dd757677(v=vs.85).aspx
https://msdn.microsoft.com/en-us/library/windows/desktop/dd797949(v=vs.85).aspx
Hi George,
Thanks, though, I'm not so much interested in this specific message as I am in demonstrating the ability to use SendMessage.
(5,248 Views)
Hi elcalverado,
here's the VB link:
http://www.ganshani.com/?s=avicap
Actually they are doing video capture, where I'm interested in doing an overlay.
Just came across this - which will help save time!
https://forums.ni.com/t5/Example-Program-Drafts/Video-for-Windows-avicap32-dll/ta-p/3491285
(5,240 Views)
