Trying to get back Manual mode of Keithley 2260B-80-27
Hi!
I was successfully connected Keithley 2260B-80-27 to LabVIEW! But now I need to change my Power Supply to Manual Mode. I tried disconnecting USB cable from the computer and shutting down VI programs. But now I can not operate the front Panel of the power supply manually. I was wondering you guys could help me for this to manual mode. I used LabVIEW examples from this website!
https://www.tek.com/dc-power-supply/2260b-30-36-software-1
Thank you very much for any advice.
(3,433 Views)
Did you try pushing the lock/local button?
(3,404 Views)
Reading the manual for the Keithley may be useful.
(3,403 Views)
Hi George!
Yeah. It was on. Then I shout down the computer. Then I could do manual operations. But it did not let me to increase current which I was running through the sample. I think manual mode is locked or something. What do you recommend?
(3,398 Views)
Hi. Thanks I will look the manual again!!
(3,397 Views)
Accepted by topic author lakshithadinusha
Hi Guys! The problem was solved automatically after installing new LabVIEW 2019 and Windows 10 to the desktop! Thanks for the help
(3,201 Views)
