Trying to get data from a bluetooth device using labview. Can anyone help?
I am currently working on a project to monitor pulse rate and need send the reading via bluetooth. My laptop is bluetooth enabled and is using a toshiba stack. I am new to LabView and need some help with this.
Message Edited by Iceberg D4 on 05-05-2009 10:58 AM
(3,823 Views)
You can definitely do this using LabVIEW. Search for labview bluetooth on NIs website to look for articles and documentation with regards to this. One thing I noticed and would like to point out:
On Windows XP - LabVIEW works with Bluetooth devices that use the Microsoft Bluetooth driver included with Windows XP Service Pack 2 and later. Refer to the Microsoft Web site for Bluetooth devices that are supported by the Microsoft Bluetooth driver. Most Bluetooth devices come packaged with a proprietary Bluetooth driver. To use the device with LabVIEW, the Bluetooth adapter must be using the Microsoft Bluetooth driver. A Microsoft Bluetooth driver for Windows XP SP1 was also available. Refer to Microsoft Knowledge Base Article 323183: Availability of Windows XP Service Pack 1 Support for Bluetooth Wireless Devices for more information about Bluetooth-compatible operating systems.
Have a look at the following:
http://zone.ni.com/devzone/cda/tut/p/id/3260
http://zone.ni.com/reference/en-XX/help/371361E-01/lvcomm/bluetooth_vis/
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,817 Views)
Thanks Adnan Zwas helpfull current working on it will keep post updated with progress.
(3,791 Views)
Hello Iceberg:
I am also starting a Labview Bluetooth application and currently in search of a USB Bluetooth adapter that works with the MS XP SP2 drivers. Please reply back if you find a USB bluetooth adapter that you can confirm works. I'll do the same when I find and get one working.
Best Regards,
Wayne
(3,768 Views)
Hi Wayne, here's a list of some supported devices hope it helps.
David aka iceberg.
(3,712 Views)
Great one there haha,  post something and forget to paste the link. Ahhhhhhhh. Novice.
Here's the link Wayne.
http://www.digitalsupporttech.com/mskb/841/841803_List_of_Bluetooth_radio_drivers_that_are_included_...
(3,711 Views)
I've used the IOGEAR USB Dongle Bluetooth adapter (model number GBU221) on a PXI with Windows XP SP2. Don't bother installing the IOGEAR driver, because you have to use the MS Windows driver. http://www.iogear.com/product/GBU221/
(3,540 Views)
