Trying to take PCAP using system exec on sbRIO via System Exec
Hello.  Running into an issue where my Modbus data is occasionally wrong.  Want to take a PCAP of data stream when it happens. I would like to automate this.  I'm using TCP dump, but what I've got is not working.  I'm clearly doing something wrong or misunderstanding something.  Any help would be greatly appreciated. If I remember with windows, I needed cmd and maybe even file paths to where it was going.  So I assume it's something like that.
(422 Views)
Can you SSH onto the target, run that command, and have everything work as expected?
If that's the case then I'd guess it's a permission issue. LabVIEW runs under the lvuser account and it doesn't have many permissions by default so you'll need to grant that user permissions to run the command. I've also had issues with lvuser not being able to find commands very well so it might not be a bad idea to just link directly to the tcpdump binary.
(408 Views)
Yes, copy and paste and it runs as expected.
This is what I was thinking, but I have no idea where it is.  Been looking for it.  Would making a .sh file be a good idea?  Just call the .sh from labview?
(402 Views)
You should be able to use the find command to find the binary. I think you would do something like `find / --name tcpdump`.
(353 Views)
Using either whereis or which both result in /user/bin/tcpdump.  So I've since updated my text to use that location and still nothing.  And again, I copy paste what I'm sending to System Exec and it works just find in powershell when I ssh into the device.
(342 Views)
Accepted by topic author LuminaryKnight
Have you updated the sudoers file to allow lvuser to use that command? Also, are you monitoring the standard and error output of the sysexec function?
(328 Views)
Sorry for the very late response.  Yes, adding lvuser to the sudoers file did the trick.
(229 Views)
