Trying to understand timing of inputs and outputs with LabVIEW FPGA
Hi
I'm trying to get a rough understanding of how timing works with inputs and outputs on the fpga and cRIO CPU when implementing control algorithms on the cRio cpu
Say I have a labview program where the following happens:
- The FPGA VI reads an analog input and sends it to a target VI (cRIO CPU)
- The target VI then makes a quick calculations and sends an output to the FPGA based on the input it received
- The FPGA then outputs this through an analog output module
Theoretically speaking, if the FPGA is running at 10 ms, and the rt target VI is running at 1 ms, will the following happen?:
- the FPGA reads the input at 0ms..
- The target VI recieves the input slightly after 0ms and calculates the an output..
- The calculated output is sent down to the FPGA before 1 ms have passed..
- The FPGA then sends this output to the analog output module somewhere around (or before) the 1 ms mark
Or:
- Or, will the calculated output be delayed until the 10 ms mark?
(3,261 Views)
What are you using to pass the data to/from the FPGA from/to the RT?  DMA FIFO?  Front panel controls?  Scan Engine?
It would help us answer your question better if you provided some code.
(3,234 Views)
It depends on how you structure your code. When you say the FPGA is "running at 10ms," it's not as though the FPGA code executes instantly, waits 10ms, then executes again; rather, you could have code executing throughout that 10ms period, where each individual piece of that code executes at 10ms intervals.
(3,163 Views)
