11-13-2007 03:49 PM
11-13-2007 03:54 PM
11-14-2007 10:03 AM
Hi Olcay,
Thanks for contacting National Instruments. Dennis is correct, Measurement and Automation Explorer (MAX) is a program for National Instruments hardware only. As such, even when you install the OMEGA supplied drivers, your card will not be visible in MAX.
The driver that is provided by OMEGA will be a library of VIs that you can open in LabVIEW. These VIs will allow you to communicate with and control your PCI card.
I hope that this helps. Please let me know if you have any further questions. Thanks-
Mallori M
11-16-2007 06:48 PM
11-19-2007 05:12 PM
Hi Olcay,
I am not familiar with the specific drivers included with your OMEGA PCI card. However, it should contain a VI that you can use to read data from your PCI DAQ card. You will need to look for VIs that have read or data acquisition functions. As long as OMEGA has not locked or password protected the VIs, you will most likely be able to edit them if they do not function to your satisfaction.
Upon driver installation, third party instrument drivers are typically placed in the instr.lib folder of the latest version of LabVIEW on your computer. This can be accessed from LabVIEW’s block diagram by right clicking to open the Functions Palette>> selecting Instrument I/O>> Instr Drivers>> then your device.
Thanks-
Mallori M
