Trying to use @ctivideo ActiveX
I recently downloaded an ActiveX control called @ctivideo from the
website www.activevideotools.com. This control is capable of getting
snapshots or sequences from video for windows cards, such as Hauppage
WinTV.
It comes with an application called @ctivideo Test GUI which is panel
you can use to check if everything is OK. You can also download the
Visual Basic 6.0 project used to create this Test Panel.
I run both the compiled and the VB6 project and they worked perfectly,
but when I try to use the ActiveX control inside LabView 5.1 it is
impossible to connect to the video driver.
Has anybody played successfully with this ActveX control.
Thanks...
Leopoldo Pena
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(2,814 Views)
