Trying to use my myRIO to wirelessly control particle photon
Looking for some help! I'm working on building a game and am having trouble connecting the myRIO to a particle photon. Essentially what I'm trying to do is use the particle photon to collect data and wirelessly send it to the myRIO where it can be accessed in a state machine. Any help would be appreciated, thank you!
(1,135 Views)
Granted it's been a while since I used a Particle Photon but I recall they are basically a WiFi enabled Arduino type of thing that uses a web portal to program them and share data.
Having to go through that web portal is probably the issue or at least adds an extra layer of complexity.
I am guessing LabVIEW web services like HTTP Get is what you are going to have use to retrieve your data from the Photon.
=== Engineer Ambiguously ===
(1,130 Views)
Thank you, is there another board that may communicate easier? Would an Arduino UNO with a BT receiver work better? I'm only using the photon because I had a few kicking around.
(1,077 Views)
Yes an Arduino and Bluetooth serial device like the HC-05 or HC06 would be a lot simpler.
As once they are configured and paired with your computer, Windows will install a virtual serial port and Bluetooth becomes transparent.
Communicating with your Arduino through Bluetooth will then be no different than communicating with and Arduino or any over device on a serial port using VISA.
Even the Arduino IDE should have no problem using the BT Serial connection.
(1,070 Views)
