Trying to write to spreadsheet...
I am trying to use a Tektronix TDS 420A oscillscope with LabVIEW to write
to a spreadsheet file that will be opened using Excel. I have tried wire
the graph output to the Write to Spreadsheet.vi, but it keeps giving me a
wiring error. Any ideas or help would be grealty appreciated.
(2,929 Views)
Reverse engineer the process of creating graph and the error will be
aparent. To create graph you have to specify three parameters t0, dt, data,
these parameters are bundled in the respective order and passed on to the
graph indicator. If you just pass data then bundling is implicit, t=1,dt=1.
If you look at the inputs required by Spreadsheet VI, you will see that it
needs either 1D or 2D array, so unbundle your graphs data and you will be
OK. Also graph is an indicator so you cannot directly wire it in the
spreadsheet VI. Anyways I would read manual, for these type of errors.
Turn on help window and check online reference Ctrl-?.
"Darrell Sharp" wrote in message
news:39451645@newsgroups.ni.com...
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(2,929 Views)
