Tunnel Wiring Wizard for LabVIEW 8
I really love this utility. It's very useful while
working with any state machine code, including LabHSM, my toolkit for
advanced
event-driven programming in LabVIEW with hierarchical
state machines and active objects.
Well, I guess, the author, David Boyd is just too busy to update
it, and I needed it for LabVIEW 8 ASAP.
Initially it was password-protected, but last October David posted an
unlocked version:
http://forums.lavausergroup.org/index.php?s=&showtopic=1996&view=findpost&p=6736
So, I had a chance to update it myself (I hope David won't mind).
It turned out to be not that much of incompatibility:
NI has changed the class ID number for the tunnels,
plus, with multiple application instances in LV 8 now,
you gotta make sure you use the correct one,
especially when running this utility from Tools menu
(place it into the "<LabVIEW>\project").
It's still made in LV 7.0 for the largest
compatibility but works in all LV versions released
after 7.0, including 8.0.
So, keep enjoying it, folks, now in LabVIEW 8 (in case
you haven't modified it yourself yet, of course)!
Thanks to Paul Sullivan (SULLutions.com) for correcting the path
definition in the code to make it platform independent
You can dowload it from LAVA forums:
http://forums.lavausergroup.org/index.php?showtopic=211&st=15&gopid=9206&#entry9206
or directly from the LabHSM site:
http://labhsm.com/Tunnel_Wiring_Wizard_LV8OK.vi
With Best Regards,
Stanislav Rumega
H View Labs
http://labhsm.com
Message 1 of 1
(3,172 Views)
