Tunnel conditional not allowed with fpga target. Any alternative?
@altenbach wrote:
@rwunderl wrote:
@GerdW wrote:
in LabVIEW FPGA it is NOT ALLOWED to create arrays of variable size!
Arrays need to be fixed in size! (And addtionally only 1D arrays are supported…)
Forgot about that little detail. It's been a little while since I needed to use FPGA code, and I've slept since then. I knew it couldn't be that simple...
But there are no arrays in your original code! Your conditional tunnel is not autoindexing.
As others have said, your code makes very little sense, conditional tunnel or not.
Note that this post is not from OP.
Message 11 of 17
(1,080 Views)
Yes, but the original code under discussion had no arrays or autoindexing tunnels. I am not sure why the discussion sidetracked into arrays. (Yes, I could have referenced it more clearly 😉 )
Message 12 of 17
(1,075 Views)
it was me talking about arrays - because conditional tunnels (as used in the example VI) only make sense for creating arrays.
When you just need the "last value" after the loop then you don't need a conditional tunnel at all…
Message 13 of 17
(1,069 Views)
Sure you do.
Returning the last value if it the value when the loop stops is a valid use case:
Message 14 of 17
(1,053 Views)
You probably meant "the last matching value".
It gets a bit murkier with a FOR loop that can iterate zero times or if the condition is never true. We probably get the default value which may (or may not) make sense.
Message 15 of 17
(1,043 Views)
Probably, not sure what to make of that sentence anymore.
Message 16 of 17
(1,037 Views)
Not sure but it seems like this is what you are trying to do: (also attached a VI)
-N
Message 17 of 17
(1,018 Views)
