Turn On/Off Tipstrip immediately when it is turned on/off for the application
Hi all,
The issue I face may be small. But still I wish to find a solution. In my project, the user is given the flexibility to turn on/off the tipstrips in the application. When he configures it to turn off and moves to 'Apply' button, the tipstrip appears for the Apply button which is fine. But once it is applied it should turn off immediately (the tipstrip of the Apply button should also disappear). But this is not happening until I move the mouse out of the button. The same happens in the reverse case - does not turn on immediately when done so. Is there a solution/workaround for it? I even tried forcing front panel update by using 'Get Image' method. Any help is appreciated.
Priyadarsini  S
P.S.: Attached VI shows the issue
(2,268 Views)
Clearing then reseting the tip strip seems to work.
(2,241 Views)
