Turn off shadow of layered items in front panel
Is there a way to disable the shadow that is cast by the top item if items are layered on the font panel?  In my case, I have a custom radio button control. I want to display a status indicator on each of the buttons. The way I planned to do this was to place the indicator on top of the button and create an event for mouse down on each indicator. However, this doesn't seem to be an option due to the shadows. Is there a way to disable the shadows or a way to insert indicators into custom radio buttons? Thanks.
(3,374 Views)
Accepted by topic author KeenanJohnson
The shadow is just at edit time to show the developer that the control is on top of for example a tab.   The shadow goes away at runtime
to preview the runtime look you can press ctrl+M to toggle between edit time view and runtime view
you can still place an indicator on top of the button as you are describing
- James
Using LV 2012 on Windows 7 64 bit
(3,367 Views)
You might also find that the shadow will vanish if you group the layered items (and you might want to do that anyway so that you don't accidentally move only one layer).
(3,358 Views)
