Turning a cluster of boolean controls into a ring menu?
Your impression is wrong. The for loop will iterate to a count equal to the number of elements in the auto-indexed array.
Message 21 of 23
(783 Views)
Newton2this wrote:
  I was under the impression a For Loop would not execute w/o wiring its count terminal.  Can you ellaborate on the For Loop function in displaying the array?  Thank You, John
Have you gone through the tutorials? Auto-indexing of loops should be covered in there.
If not, it's in the manual. You know, that thing that's got a lot of words that nobody reads. Smiley Very Happy
Message 22 of 23
(776 Views)
Hi Newton2this,
Have you looked into any of our resources for learning LabVIEW? Like some of the other posters mentioned we have the LabVIEW Getting Started Guide which installs with LabVIEW and the LabVIEW Help, however for a more guided experience we have classes all over the World for LabVIEW, you can view options by going to http://www.ni.com/training/. You can also check http://www.ni.com/labview/learn_lv.htm for a variety of other ways to learn LabVIEW.
With warm regards,
David D.
Message 23 of 23
(734 Views)
