Turning a pink or red line into an orange line
the pic I have up there now only records the first digit
Message 11 of 20
(3,567 Views)
@Falcon9a wrote:
Where is the DBL converter located?
Programming > Numeric > Conversion
Richard
Message 12 of 20
(3,564 Views)
That's because the second thing in the string is not a number, it can't convert it.
Why don't you use Present (s) which is already orange, I mean a DBL?
Richard
Message 13 of 20
(3,560 Views)
@Falcon9a wrote:
That's just silly and a waste of code. Do what I said about using the correct output of the function since you do not know how to do the conversion and doing the conversion is, as I said, silly.
Message 14 of 20
(3,553 Views)
Sometimes small words big pictures helps
Message 15 of 20
(3,548 Views)
Dennis: The Elapsed Time output isn't going to give him the Date, which we wants.
The OP could log all of his data as strings, that way Time, Date, PM, AM etc can be logged Smiley Tongue No more pink to black converters. Smiley Tongue
Jeff: that's what I said.
Richard
Message 16 of 20
(3,546 Views)
The numbers that my program record have to be compared to a separate recording, I figured it would be good to at least know how to make a present time text recording since they might not use the present (s) convention to record their data.
Message 17 of 20
(3,536 Views)
So as I said, you can convert those two data points to strings, then just wire up Present Text straight to the Build Array. (The write VI is Polymorphic, it'll take numbers or text).
According to the way your VI is written, it may look like this.....
No silly Express VI Smiley Tongue
Richard
Message 18 of 20
(3,534 Views)
No problemo! changing a timestamp scale and epoch is kitty play---- for instance if you want a LabVIEW time stamp to be a dbl that Excel (or any MS Office product) uses just use this-
 Its been in the code shareing area for years.
If you need another format (scale/epoch) it's pretty easy to do once you know the details
Message 19 of 20
(3,521 Views)
I guess the orage wire has the right value now
Message 20 of 20
(3,480 Views)
