Turning coordinates into an object represented in an image
Hi, I'm trying to turn a set of 6 coordinates into a representation of an object. I'm hoping to put this into an image with the object filled with a color. I'm going through ways in which it might be done, but was wondering if there might be a VI already available that could do it.
(2,533 Views)
Yes, you can use the Draw Multiple Lines function with a 2D picture control.
(2,500 Views)
Thanks a lot, I think it works :).
(2,489 Views)
