Turning off and on an LED in a stacked sequence
I have all that figured out but now I need to set up the enum constants in the case structure that tells what case to execute right? and then that gets wired to the right side shift register
Message 31 of 37
(1,189 Views)
Correct.
The easiest way is to work one case at a time.  Drop in a copy of the typedef'd constant near the tunnel.  Select it to be whatever item you need to match the old constant that is already there.  Delete the old constant, wire up the new.  Move on to the next case.
Message 32 of 37
(1,184 Views)
so basically just copy and pasting??
Message 33 of 37
(1,181 Views)
Correct. If you, on the diagram, copy the existing typedef enum (wired to the outside of the left shift register node) to each of the locations inside the cases and set them to the correct case for the next step in the state machine, that should do it. Don't use the original ones that were in the various cases as they won't be linked to the type def, will result in "coercion dots", and won't update automatically if you edit the typedef to add new cases.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 34 of 37
(1,181 Views)
Okay sweet I have it running now...Ill copy the program again of what I have. Some of my LEDS are working and some arent, did I do it right by placing false constants on the cases where the light should be off??? Console 2 turns on in Frames 5 and 7 like it should but none of the other LEDS are turning on at all...any ideas?
Message 35 of 37
(1,178 Views)
sorry heres attachment
Message 36 of 37
(1,175 Views)
wow...what a thread! haha
Message 37 of 37
(1,154 Views)
