Tutorial for Excel application wrire and read
Dear Sir/Madam,
Now i am working with labview 7.1 version for my project. In my application i need to work with  MSExcel..But i dont know the procedure and proper steps for building an application for reading an excel file as well as writing the data into the sheets.
Could you please provide some e-books or manuals for Learner/Starter..
Thanks In Advance
Krishnamraju
(2,661 Views)
I had the same case when i wanted to learn how LV and MS Excel can work together.
Here you can find many good solutions and links to other treads. Since you use an older version of LV, you can ask for a conversion here if some of the .vi files are created in a newer version.
I also found a nice post on the Lavag.org forum. My problem was to read/write data without the use of the Office Report Generation Kit from NI. You can use spreadsheets, but I have a little lack of skills there. If you look at the Excel Board in the first link you will find a free library that help you with Excel and ActiveX.
Even
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(2,651 Views)
