Two 2-State (T/F) Inputs to One 4-State Output: Case Structure Control
I would like to convert two 2-state (true/false) inputs to one 4-state output to specify a Case Structure state. I looked at the Enumeration and Ring Control components, but these only have one output port. Is there a two-port component that accomplishes this function?
(2,582 Views)
Use built array to create a boolean array with two elements, then use "boolean array to number".
Wire that number to the case selector and make cases 0, 1, 2, and 3 (corresponding to cases [0,0], [0,1], [1,0], and [1,1], resp.).
(2,581 Views)
