Two Easy Ways to Hang LabVIEW 8.5
Method 1:
1.  Place a "TCP Open Connection" primitive on the block diagram of a blank VI
2.  Wire an empty string constant into the "remote port or service name" terminal
3.  Run the VI
Method 2:
2.  Wire any non-empty string into the "remote port or service name" terminal
3.  Wire a '0' into the "timeout ms (60000)" terminal
4.  Run the VI
Is anyone able to do this without hanging?
This is obviously a problem with the NI Service Locator.
NI, is this a known issue?  If not, could you post the CAR numbers you file?
Robert Mortensen
CLA, CLED, LabVIEW Champion, Principal Systems Engineer, Testeract
(3,301 Views)
With Automatic Error Handling Enabled on the VI:
Method 1 generates Error 1, An input parameter is invalid.
Method 2 Generates Error 56, Timeout.
Neither one causes 8.5 to hang for me.
With Automatic Error Handling Disabled on the VI:
Both cause 8.5 to hang
Interesting
Message Edited by Ed Dickens on 11-02-2007 03:44 PM
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,279 Views)
Hi Robert.  Thank you for bringing this to our attention.  I have submitted a CAR on this and I am waiting to hear back from our Research and Development department.  I will post the CAR details as soon as they are processed.  Thanks again!
Meghan M.
(3,203 Views)
