Two Planes Balancing
The vi below is version Labview 8.2.  Can someone please save it as 7.1.
http://zone.ni.com/devzone/cda/tut/p/id/4381
(3,249 Views)
Hi Kyle,
I attached the main VI for version 7.1.  This should be enough to give you an idea of what is going on.
The project in that DevZone uses the PDA Module that was released around LabVIEW 8.0.  To use this you will need to upgrade your software version.
Let me know if you have any questions
Justin Parker
Product Support Engineer
(3,209 Views)
