Two Similar c-RIO-9035 but different start up behaviour
We have two similar type testrig and used two c-RIO-9035(c-RIO1 & c-RIO2) having same code.
when i switch on the c-RIO  then cRIO1 is switch on within 30sec and another cRIO2 is switch on after 2 mins.
As everying is similar of the both rig.
No file is missing, No Error at time of initialisation of code and no difference in both code.
I have attached NI Max Startup setting screenshot of cRIO2.
is there any setting issue or anything else?
Could anyone please help me for find the reason for delay start up of cRIO2?
Note: after start up both rig are work fine and same behavior. Only at time of start up facing delay issue.
(1,373 Views)
Do both cRIOs have the same firmware version? What do you mean by "switched on"? It's when your start-up application starts running? How do you know when that happens? You switch ON some LEDs? Are you sure both are 9035? I see in your screenshot that a 9045 is also connected.
Lucian
CLA
(1,339 Views)
Sorry for that, Its cRIO 9045.
Yes, both are same firmware version and startup application is running fine. both have same startup application.
Only when power on the both cRIO, one is switch on within 30sec and another is taking 2min.
I check with by ping from command prompt and also through GUI.
(1,313 Views)
