Two VIs interfering with one another
One VI is for RTDs and pressure gauges.  Another VI is for flow meters.  If I were to run the RTD+pressure gauge VI alone, the values read correctly.  If the flow meter VI is run simultaneously with the RTD+pressure gauge VI, the values of the RTDs become innacurate after around 15-20 iterations every time.  What is causing an interference between the two?
Eight RTDs and two flow meters are on a LabJack U3.  The 2 pressure gauges and third flow meter are on a LabJack U6.
(1,758 Views)
You are using mostly third party labjack drivers and it is not clear how well they are written or called. Have you tried their support?
(1,750 Views)
