Two Wave Forms to Scaled Data to Spreadsheet
I followed and example from ftp://ftp.ni.com/contrib/epd/B45EACE3DC0456A4E034080020E74861/Hysteresis_Characteristics_of_Magnetic_Circuits.zip that includes an image of example code that I can not get to work. My code, which I included, is supposed to scan two channels, acquire the waveforms as scaled data, and write the time and waveform plot points in three columns. I get the "y" plots ok, but the time column is full of zeros.
I'm using Labview 6i. Any help getting the correct time stamps would be appreciated.
(2,755 Views)
Hello.
The output of the AI Wave VI you are using is NOT an array, but a single number, so when you form an array out of it and a 0, you get an array with 2 elements, a 0 and your sample period, and the rest of the array is completed with zeroes. I am attaching an image of a way to achieve what I understand is what you are trying to do. I use a for loop and the sample period output of the AI Wave VI to create a "time" array with elements corresponding to the time at which each sample was taken. I hope it works for you. (I am attaching an image because I cannot save the VI in version 6i).
(2,755 Views)
Thank you for your help. I was following an example that was included in the download that is linked to in my original post. It had me pulling my hair out.
(2,755 Views)
