‎06-24-2009 07:00 AM
Hi!
I had connect in my SCC-68 two things. One led in the ao0(screw terminal 22) and aoGND (screw terminal 55), and one loud-speaker in ao1 (screw terminal 21) and aoGND(screw terminal 55).
I try to generate a sinus sugnal to ao1 and a DC signal to ao0. Separetly they work, but in the same time they didn't...
I had try in Labview, and in SignalExpress too...
Any help?
Thanks: Koli
Solved! Go to Solution.
‎06-24-2009 07:08 AM
Hi Koli,
how did you try to use both? You can create only one task, because the ao are multiplexed. You can use both outputs on the same task.
Mike
‎06-24-2009 07:09 AM
‎06-24-2009 07:54 AM
I have a Daq card... (NI PXI-6251 M series Multifunction DAQ)...
Here is two pictures how i tried it...
‎06-24-2009 09:00 AM
‎06-25-2009 02:31 AM
Hi!
I didnt find this DAQ Assistant thing...Where is it?
Once i had make a mistake and i had delete one shortcut in the start-menu, but i dont know what had i delete...Maybe this?
Here is a picture from my start menu:
Thanks:Koli
‎06-25-2009 02:44 AM
Hi Koli,
you already use it in your code. The Express vi's which you marked with ao0 and ao1. 🙂
Mike
‎06-25-2009 04:14 AM
