Two cameras at the same time Lab view (NI MAX)
I have two similar Point Grey Firefly MV cameras. I need to use them simultaneously in LabVIEW, but NI MAX only detects one at the same time (the two cameras are detected properly separately). I think that NI MAX identifies both camera as the same camera, but I dont know how to change the name of one of those cameras, or maybe change the serial number. Also NI MAX gives the same serial number to both of them. I would apreciate your help
Thank you.
(2,939 Views)
May be a camera problem.  What sort of interface are they?  We've got 24 Axis Ethernet cameras, plus several miscellaneous USB cameras, and MAX sees all of them.
(2,919 Views)
Hi Aurelio,
This is a commom issue for USB Cameras. Once IMAQdx calls the camera driver to acquire image, if the camera driver cannot acquire from 2 cameras, IMAQdx cannot acquire from 2 cameras too.
You can ask to camera vendor about how the camera driver works.
http://digital.ni.com/public.nsf/allkb/D13527D8471D5FC5862576A4006BD081?OpenDocument
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(2,885 Views)
Yes. It was a problem with the driver of the camera for directshow applications. It doesn't allow to work with two cameras simultaneuosly.
Thank you.
(2,860 Views)
