Two cameras take photos simultaneously at the same frame rate
I would like to write a vi to have two cameras take photos simultaneously at the same frame rate. One camera is a Lasercam HR II and the other is a gigE 680. If you could point me in the right direction, I would really appreciate it. I would like to know,
1) Is it possible to sync the cameras?
2) If so, how do I genlock them?
Thank you!
(3,476 Views)
I would like to write a vi to have two cameras take photos simultaneously at the same frame rate. One camera is a beamview
(3,470 Views)
Accepted by topic author sfsu
Hi sfsu,
Based on your description, here is are the cameras I think you are using:
LaserCam-HR II - https://cohrcdn.azureedge.net/assets/pdf/LaserCam-HR-II-User-Manual_FORMFIRST.pdf
Allied Vision Prosilica GE680 - https://www.1stvision.com/cameras/AVT/Prosilica-GE680-GE680C.html
Based on the datasheets for both, it looks like you could use an external hardware trigger to take images.  As far as synchronizing them, I would think that you could use a single DIO port (assuming that the two cameras use the same triggering circuitry), and trigger them both off the same line.
Regards.
George B.
(3,402 Views)
