Two controllers controlling single motor
I have a problem in connecting two controllers with a single motor
I am using two sbRIOs from which I get a  pid output varying from 0volts to 5volts(between AO & AOGND of same board)
I want to give this output to a fan whose speed is under control through a BNC  cable
how can I switch the output from one controller to the other in order  to drive my motor without manually changing the terminals....
Message 1 of 1
(2,500 Views)
