Two equal consecutive integers
An here's a (maybe) slightly more elegant solution. 😉
Message 11 of 32
(2,347 Views)
altenbach; I have changed the way i represented the wait (should have guessed to represent it as the TF array). I removed the constant value linked to N but I haven't understood the particular comments:
"For small array diagram constant, I would always show the first out of range element so it is clear how big the array really is. If you don't, it could be much longer than the display. (For large array diagram constants, simply show the scrollbar)."
"You could also use a feedback node."
As for the second solution, I'll try to understand the %09d format.
Message 12 of 32
(2,338 Views)
Your array diagram constant was sized to exactly show the array elements. Since I don't trust what I see, I resized it one element bigger to ensure we are at the end of the array. The container size and the actual arrays size are independent.
Well, in my Mod2 example I used a feedback node instead of a shift register. same difference.
What is there to understand. It simply formats the number in decimal with a minimum size of 9 digits and adds leading zeroes if the number is smaller than 9 digits. Check the help on Format Specifier Syntax. Do you understand the rest, e.g. why we subtract 48?
Message 13 of 32
(2,330 Views)
Sorry I didn't reply earlier; It was almost 1 a.m.
If I am not mistaken the %09d format changes the number to x.xxxxxxxx
I didn't find the palette that is linked to the Enter Your Number ID, but I think we subtracted the 48 due to the 8 digits (represented as hexa decimal) after the decimal point. The maximum distance between 00000000 and 77777777 is 48
I'm not sure though.
If I'm mstaken how does it represent for example 123456789?
Message 14 of 32
(2,313 Views)
Don't you think we've done enough of your homework?
Message 15 of 32
(2,298 Views)
LOL thats my friend!
I told him that ni has forums that both help and teach you new programing ideas.
I am sorry if we caused any inconvience but we came to learn\improve from our LabVIEW mistakes.
Message 16 of 32
(2,287 Views)
Hmmm.... two people working on exactly the same problem. Hmmm.....
Honesty is a rare commodity these days.
Message 17 of 32
(2,276 Views)
No!
No!
Message 18 of 32
(2,270 Views)
Both of us are working on the exactly the same problem of a homework ...
But what differs us from the rest of the class is that we ask what is vague and...
Other examples:
http://forums.ni.com/t5/LabVIEW/How-to-use-the-XY-graph/m-p/1757526#M613034
http://forums.ni.com/t5/LabVIEW/Problems-with-the-quot-INSERT-quot-button/m-p/1765592#M614473
I have mentioned here thatI had a homework but I needed help in it.
Message 19 of 32
(2,266 Views)
There is nothing wrong with asking for help with homework, especially if you try to solve most of it yourself and ask specfic questions here (e.g. "Is there a way without using local variables to do that?") is a good question. 😉
The internet is a great resource to solve problems and asking questions in a forum is a valuable learning tool too. 😄
Message 20 of 32
(2,256 Views)
