12-02-2005 03:16 AM
Hi David,
I guess that measure frequency VI uses both the counters to measure frequency.
And using a single counter, you can only perform a period measurement.
so what i usually do is find inverse of period measured by a single counter and use it as frequency, whenever i have to use both the counters in a multifunction E series daq card
can u tell think of a better way?
regards
Dev
12-02-2005 03:18 AM
Hi David,
regards
Dev
12-02-2005 07:20 AM
The DAQ-STC has two counters. Typically both are required for doing one frequency measurement. BUT the VI I attached in the thread before demonstrates how to measure two frequencies simultaneously using the DAQ-STC counters by using an analog output channel (instead of a counter) to generate the required gate signal. This frees up the second counter to be used for frequency measurement.
Besides, Your way of working is great..
Regards
DD
