Two instances of LabVIEW IDE
@JÞB wrote:
Again, it is frightening enough that few Champions dare tread the path.
I don't know about frightening. In my case it was simply a matter of not having any actual need for it. There are certain EXEs you build for which this behavior could be useful, but unless you want to do something like running a long compile on LV and can't set up another machine or VM to allow working in parallel, I haven't found the need for this in LV.
___________________
Try to take over the world!
Message 11 of 14
(523 Views)
I stand corrected!  Yair will dare the dare-  Or perhaps I am confirmed?  Yair is one of the few people I would not expect to be confussed by LV context EVER!  (Do not drink-and-NI! Trust me!)  The "Few" Champions that would dare to develop code with multiple instances of the same LabVIEW.exe open can exclude me.  Go ahead- call me a chicken!  bock-bock!
Message 12 of 14
(494 Views)
The first thing the second instance of LV wanted to do was recover the files open in the first instance.....
Message 13 of 14
(483 Views)
@Intaris wrote:
The first thing the second instuse project tance of LV wanted to do was recover the files open in the first insttance.....
And this did not frighten you? ...........if it did not.... why the post?
OK the recover stuff is swell!
But, Two instances of the IDE is a condition that causes me concern.   It "Should be" manageable but requires more awareness of context than I usuallly have.
Now, If you pay close attention to those clues that the IDE does provide you with.....Sure! you can develop code in both contexts!  I, on the other hand, am meerly human.  I quit LabVIEW fast when this happens.
Message 14 of 14
(471 Views)
