Two or more cluster with different contents at Case-output
Hallo community,
I am having an issue with putting contents of two different clusters at the same case-structure output.
See pictures:
Is there any way to resolve this issue? I didn't think this would be a problem because I am not putting the contents of cluster 1 into cluster 2...
Thanks in advance,
Musa
(747 Views)
Accepted by topic author musa_
A wire can only contain data of a specific type. Since you already have cluster values flattened to a string, you can directly write the string to the file, provided that the endianness is ok.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(724 Views)
