Two "Wait for Notification" with single Notifyer?
I feel like I should know this answer, but my code was buggy when I did this.
Can you have multiple "Wait for Notification" VIs attached to the same Notifyer?
The help seems to suggest that Notifiers are only for two independent loops:
Notifiers are a tool for communicating between two independent parts of a block diagram or between two VIs running on the same machine.
(2,694 Views)
Accepted by topic author hecmar.arreola
Can you have multiple "Wait for Notification" VIs attached to the same Notifier?
Yes 😄
See the Notifier Demultiplexer example.
(2,682 Views)
Hmm..my bug must have been related to something else then...
(2,663 Views)
