Two signals on two outputs with specific time interval
I cant manage with following:
Have NI-6251 card. Trying to sent two step-signals on two outputs with
specific time interval, say 1 to 10 ms with 1us accuracy.
How can I start?
Thanks!
(2,512 Views)
Hi Anonymous,
What do you mean by step-signals?  Do you mean a signal that steps up the voltage over time, a step function signal that is zero until a certain time then goes to 1, or a pulse train?
In the meantime you can find examples for getting started in the NI Example Finder by selecting Help » Find Examples
When that opens you can limit the examples to ones that are compatible with your hardware.  In the bottom left corner select your hardware and check the Limit results to hardware box.
Browse to Hardware Input and Output » DAQmx » Digital Generation or Generating Digital Pulses.
Best Regards,
Bryan H.
(2,490 Views)
